What did you do to your crx today?
Re: What did you do to your crx today?
Postby As I Conspire » Sat Apr 06, 2013 12:35 pm
what are you doing with the old engine?
As I Conspire
AIC Designs
Postby 4drSpankR » Sat Apr 06, 2013 5:03 pm
the old motor is as of this morning, in a scrap yard. Made a listing on CL for anything people needed and got rid of the rest. I was kinda sad to see it go.
4drSpankR
Postby As I Conspire » Sat Apr 06, 2013 6:06 pm
really...... i wouldve came and got it. ill be in that area next weekend.
damn...
As I Conspire
AIC Designs
Postby 4drSpankR » Sat Apr 06, 2013 6:37 pm
unless you wanted to rebuilt it, the block was no good. It started knocking due to a faulty oil pump.
4drSpankR
Postby As I Conspire » Sat Apr 06, 2013 6:50 pm
i wouldve been willing.
As I Conspire
AIC Designs
Postby 4drSpankR » Sat Apr 06, 2013 6:56 pm
Ahh that sucks, didn't even think to post it on here. I never had a problem with that motor, always started right up, never smoked (even with high mileage) or had smelly exhaust. It probably helps I changed the oil every 2500 miles though, that motor was clean.
4drSpankR
Postby As I Conspire » Sat Apr 06, 2013 7:08 pm
thats too bad. was looking at that exact motor to do a build with.
As I Conspire
AIC Designs
Postby AZCRXSI » Sun Apr 07, 2013 1:02 am
Absolutely nothing today.
Is that bad?
I did see Adam Carolla live tonight thought… Excellent show!
1990 CRX Si BUILD THREAD
AZCRXSI
Postby Cementups » Sun Apr 07, 2013 1:28 am
I had pulled my wiper arms to paint them but then had to run to Ace to get different paint. My boy fell asleep on the way home and I took him inside to take a nap on the couch and ended up falling asleep myself. Guess I'll try and get that done today.
meanwhile, here's my copilot passed out on the way home:
Cementups
Postby Cementups » Sun Apr 07, 2013 1:29 am
Cementups
Postby As I Conspire » Sun Apr 07, 2013 1:44 am
sounds like your getting old man :)
As I Conspire
AIC Designs
Postby MexiChriS » Sun Apr 07, 2013 2:28 am
April 4, 2013 - D16z6 P28 ECU Conversion
Fixed my ECU, converted it from auto to 5-speed manual
April 6, 2013 - 50% off Junkyard Deals
Hit up the junkyard in Lancaster, CA @ Ecology to help a good friend of mine; Ely, get a rack and pinion assembly for his EF9 hatchback. Reason for this. Drinking and driving isn't worth it!
Also caught eye on a Civic Wagon (auto) if anyone cares to get parts
Anyways, got that assembly for him and I went to snatch a few things to complete my build!
- Shift boot from '89 Civic Sedan LX
- Crossmember bolts
- Shifter lever assembly bolts
- VW Jetta front lip '94
Lip seems smaller than '95 and has minor crack at bottom right
- VW Jetta front lip '95
Lips seems slightly bigger than '94 and minor issue center not connecting flush anymore
So I cleaned + installed my crossmember.
Cleaned up that filthy shift boot.
Thoroughly cleaned VW lips for repair.
Then I [potty mouth] up my lower driver side plastic garnish molding piece. Lowering jack, sliding accident, onto jack stands. Must buy this now before painting my CRX Si.
Aside from that, all I'm missing now due to loss is a bitch pin (spring pin 8x20) + the clip that slips over it on the shift linkage and a cotter pin (lower ball joint nut holder)... Stopping by my local Honda dealership for these soon
1988 CRX Si (shell) D16z6 OBD1 In Progress <--- Build Thread
1990 Civic Wagon D15b2 (SOLD)
1972 Datsun 240z - L24 w/stock SU Carbs (SOLD)
MexiChriS
Postby Braffy » Sun Apr 07, 2013 7:58 am
Both of those VW's are 95's, 10th vin digit is S for both of them. Usually cars here get marked as the new model year around October. My CRX is a 90, but was built in October 89.
Braffy
Postby Regiscrx » Sun Apr 07, 2013 8:10 am
Mmm... You could may be help me... Are these buckles ( or at least 1.... ) equiped with the seat belt warning system ??? ( wired seat belt buckle ). If yes, what's the part number of that buckle if you still have it from Honda???
( or sometimes, there's even a sticker with the part number on it on the buckle itself... )
Thanks,
Regis.
Austin_tacious wrote:Went to the Honda dealership and got some shiny new seat belt buckles. :-)b
They also gave me a 27 point inspection, so I can worry about everything I need to replace. :lol:
Sent from my iPhone using Tapatalk
Regiscrx
Postby 4drSpankR » Sun Apr 07, 2013 10:30 am
Cleaned the engine bay thoroughly, it helps when the motor is out. 8) And installed my new(er) driver's side front fender. The old one had a really attractive dent right after the wheel but before the door, it looks soooo much better now.
4drSpankR
Postby Cementups » Sun Apr 07, 2013 11:03 am
As I Conspire wrote:sounds like your getting old man :)
There's no gettin' about it. I'm 38 and have a bad habit of staying up late at night. The combo catches up to me. :zzz:
Cementups
Postby clarkracing39 » Sun Apr 07, 2013 1:06 pm
put in the roll cage and got everything else tied up so it's ready for the race track this coming weekend
clarkracing39
Postby MexiChriS » Sun Apr 07, 2013 2:43 pm
Braffy wrote:Both of those VW's are 95's, 10th vin digit is S for both of them. Usually cars here get marked as the new model year around October. My CRX is a 90, but was built in October 89.
haha well that's an obvious.
Car makers have been doing that for a long time now. Because of that it's always been an issue trying to find a legit early '69 or '70 Datsun 240z. So I definitely know about it..
I only stated year model with pictures and door jam sticker-vin info of both. So people know + see what model to get a VW front lip off of. People are blind and lost when hunting.
Confused though, as those two lips differ in size a tad bit. I'll be taking measurements to make sure about it
MexiChriS
Postby KevinEF7 » Sun Apr 07, 2013 3:21 pm
Cleaned the interior glass, needed it so bad
KevinEF7
Postby Zackcal1899 » Sun Apr 07, 2013 5:55 pm
Wet sanded and buffed my 90-91 tails! Now to decide whether or not to put the sticker I got from Rommel on them or leave it shaved for a little while :lol:
89' Crx Si
My SLOW Build Thread
http://www.crxcommunity.com//viewtopic.php?f=26&t=51069
My Feedback!
http://www.crxcommunity.com/viewtopic.php?f=25&t=64740
Zackcal1899
ZackAttack
Postby Cementups » Sun Apr 07, 2013 6:21 pm
Been trying to get these damn wiper arms painted and put back on but it keeps trying to rain on my parade. Literally. Rain. Ugh.
Cementups
Postby TYetti » Sun Apr 07, 2013 8:56 pm
fed mine money picked up the rest of my bushing kit, then whipped out the credit card to order more suspension parts lol at least this way i wont have to worry about parts letting go on me while driving
TYetti
Postby Mista Bone » Sun Apr 07, 2013 10:17 pm
Remove the VAFC-II and relocated the oil pressure gauge to make room for a radio only to find out all the radio wiring was cut. Also replaced the weighted Skunk2 like shifter knob and reinstalled the OEM, much better!
BoneSpec Transmission
"D" Tranny guru
Mista Bone
Postby Rommel » Sun Apr 07, 2013 10:56 pm
Zackcal1899 wrote:Wet sanded and buffed my 90-91 tails! Now to decide whether or not to put the sticker I got from Rommel on them or leave it shaved for a little while :lol:
Put the sticker on :club:
Mista Bone wrote:Also replaced the weighted Skunk2 like shifter knob and reinstalled the OEM, much better!
Why didn't you like Skunk2 shift knob :shock:
1990 CRX DX A/T to M/T Swap & B16B
http://crxcommunity.com/viewtopic.php?f=26&t=55978
Rommel
Postby MexiChriS » Sun Apr 07, 2013 11:08 pm
Removed my '88 CRX Si door cards to fix minor dings to prep for my own paint job.
Driver side plastic crank lever had to be destroyed in the process. Whichever previous owner, before me, glued it on rather than using the spring clip + lost the round trimming that makes it flush on door card.
Also, my passenger speaker is falling apart. Yet another thing I'll have to purchase. It's a must.
On the positive side. Possibly might install my power windows, if I get everything planned out, before hand that is.
Long awaited task. Looking forward to this.
MexiChriS
Return to The Lounge
Users browsing this forum: fraglerock, Yahoo [Bot] and 3 guests
