Help!! Glass Roof JDM CRX??
Postby Deeves » Wed Jun 13, 2012 7:49 am
I originally thought a 1991 CRX Si was the rarest/best type of CRX out there. However, just this morning I stumbled upon a CRX JDM SiR that appeared to have a glass roof...? It was beautiful and the coolest CRX I had seen by far.
I tried to search for CRX JDM SiR's for sale but not much came up. Does anyone know the official model of CRX I'm referring to? Was it only manufactured in Japan? Are they even available here?
Thanks in advance for the help.
-Deeves
Deeves
Re: Help!! Glass Roof JDM CRX??
Postby Deeves » Wed Jun 13, 2012 7:54 am
And what are the EF8 and EF7 references I'm seeing??
Thanks again for the help.
-Deeves
Deeves
Postby ScottMog » Wed Jun 13, 2012 8:00 am
Glasstops are not available here, I'm fairly sure that was a japanese only option, BUT! and this is a large but... it may be a RHD and glasstop conversion.
Go ahead and go to your user control panel on the top of the site and choose profile. In there you can add your city/state or country.
EMAIL ME instead if possible. scottmog@gmail.com
Haters gonna hate
ScottMog
BlabberMouth
Postby ScottMog » Wed Jun 13, 2012 8:01 am
Eh, another note... it is possible to drill spot welds out and put in a glass top and redo the taps. Or sometimes people chops the top of the crx off and do it that way :(
Haters gonna hate
ScottMog
BlabberMouth
Postby Baker » Wed Jun 13, 2012 8:25 am
Deeves wrote:I tried to search for CRX JDM SiR's for sale but not much came up.
Really?
A simple overview
http://en.wikipedia.org/wiki/Honda_CR-X
Postby Deeves » Wed Jun 13, 2012 9:51 am
Really?
A simple overview
I should have been more specific. Sure things came up, but I couldn't find any for sale, and I didn't find a lot of information about them.
Thx for the help y'all. What about the EF8 and the EF7? What is that in reference to?
Thx.
Deeves
Postby Baker » Wed Jun 13, 2012 10:01 am
Deeves wrote: What about the EF8 and the EF7? What is that in reference to?
Those are referring to the chassis code, which tells what model it is.
Again, this is info that is out there.
http://www.civicforums.com/forums/3-gen ... ution.html
Postby Deeves » Wed Jun 13, 2012 10:53 am
Cool cool. Thanks Baker and ScottMog for the help!
-Deeves
Deeves
Postby Baker » Wed Jun 13, 2012 11:00 am
Deeves wrote: Was it only manufactured in Japan? Are they even available here?
Also, the SiR and equivalent European model known as the VT were not available to markets on this side of the globe.
All Crx's though were made in Japan.
Postby JesSi00 » Thu Jun 14, 2012 1:26 am
Here is a pic of my glass top. Like scottmog mentioned one way of installing is drilling out the spot welds and welding in the glasstop.
You can also check out Los.'s CLEAN RHD Glass Top
http://crxcommunity.com/viewtopic.php?f=26&t=52433
•BRIDGEPORT•
JesSi00
Postby ScottMog » Thu Jun 14, 2012 7:57 am
Wow... I was in carlos's garage and didnt even notice it had a glasstop... wtf'd
Haters gonna hate
ScottMog
BlabberMouth
Postby AlexCRX » Thu Jun 14, 2012 3:58 pm
The best way to do it is drilling the spot welds...
I saw on another site(I don't remember which one) the guy glued it on his existing roof... in my mind this is a shame to do that
CDM 91 Si
CDM 91 Si Special Edition mint!
USDM 91 HF
AlexCRX
Postby daveb91 » Thu Jun 14, 2012 4:31 pm
AlexCRX wrote:The best way to do it is drilling the spot welds...
What? Glued the glass on top of a steel roof? Or glued the panel in after removing the stock panel? Using epoxy or glue is actually a very good way of installing the panel.
daveb91
Postby JesSi00 » Thu Jun 14, 2012 6:10 pm
^^^ I know a guy that did it that way. Removed the spot welds from the glass top cut up the roof on his Rex and layerd the GT roof with some special type of adhesive and never had a problem. If I dont have the funds for welding this might be the direction I'll be going with.
•BRIDGEPORT•
JesSi00
Postby AlexCRX » Thu Jun 14, 2012 10:20 pm
no he glued the metal part over the existing one... without removing winshield... this is ridiculous
The guy edited his post on honda-tech and removed all his pics...
basically he didnt remove his existing roof, he cut it enough for the window roof to clear, and then he glued it over what's was left of his existing roof... crappy job!
the GOOD way to do it is to remove all spotwelds and remove the existing roof, then weld/glue the glastop
CDM 91 Si
USDM 91 HF
AlexCRX
Postby JesSi00 » Fri Jun 15, 2012 12:27 am
I have seen it done like that as well and the owner of that Rex never had a problem, I belive he called it the layerd method. He said it worked great.
•BRIDGEPORT•
JesSi00
Postby AlexCRX » Fri Jun 15, 2012 10:05 pm
It's his car, but in my mind (I used to work in body) it's a crappy job
CDM 91 Si
USDM 91 HF
AlexCRX
Postby TheLukeMartinez » Sat Jun 16, 2012 10:25 am
AlexCRX wrote:It's his car, but in my mind (I used to work in body) it's a crappy job
I'd say go all out with the full roof swap. If you don't have the funds for that, please don't ruin your roof :-)b
1989 Honda CRX Si B16A -Peppy DD-
1990 Honda Wagovan DX -Low N' Slow-
2000 Honda Odyssey EX -The Wife's-
TheLukeMartinez
Postby AlexCRX » Sat Jun 16, 2012 1:21 pm
well said!
CDM 91 Si
USDM 91 HF
AlexCRX
Postby asianflava » Sat Jun 16, 2012 7:16 pm
Layered method? Bah! What a lazy POS way to do it. If you don't have the resources or skill to do it correctly, find somebody who has them or DON'T DO IT!
That's the kind of car that will find it's way to eBay (or CL) then some kid will buy it, have all kinds of problems, and show up here asking for all kinds of help to fix his hacked up car.
91 CRX Si (hers)
89 Civic Si (his)
01 Toyota Highlander (hers)
07 Toyota Tundra (his)
asianflava
Postby jfrolang » Sun Jun 17, 2012 11:49 am
The overlap method is an established roof panel replacement procedure. It's even patented. It's not a "lazy POS" method, it's simply more efficient.
jfrolang
Site Admin
Postby daveb91 » Sun Jun 17, 2012 12:51 pm
jfrolang wrote:The overlap method is an established roof panel replacement procedure. It's even patented. It's not a "lazy POS" method, it's simply more efficient.
When done right, I can't comment on the H-T users build because I never saw it.
daveb91
Postby JesSi00 » Tue Jun 19, 2012 1:39 am
asianflava wrote:Layered method? Bah! What a lazy POS way to do it. If you don't have the resources or skill to do it correctly, find somebody who has them or DON'T DO IT!
Lazy! I think not good Sr. This method takes about the same amount of time and labor it does to weld it only reason Im considering doing it this way is because I dont know how to weld and Im not a big fan of paying some one to do things for me. I cant speak for other car owners who "Mod" their car and end up selling it just to get rid of their problem.
I agree!! (lol I didnt know it was patented)
Here are some pics that I got from another website, these are not mine.(mods Ill take them down if I have to Just let me know) This Rex belongs to SirMarlon who never had a problem with the install.
(all pics belong to SirMarlon)
Product used
Finished Product
He even tracked his car a couple of times with no roll cage and said it felt great. :-)b
•BRIDGEPORT•
JesSi00
Postby ScottMog » Tue Jun 19, 2012 9:14 am
omfg, you were parting out that crx a couple years back on HT huh? car looked beautiful...
Haters gonna hate
ScottMog
BlabberMouth
Postby Jee-F » Tue Jun 19, 2012 10:16 am
wow, is that guy on this site? I always wondered about replacement moldings if you take the glass out like he did
IG: Jee_Kay88 (mostly CRX pics)
2003 Civic Street Edition - DD
Mugen EF8 - Project -B16s suck
Jee-F
Return to The Lounge
Users browsing this forum: fraglerock, Yahoo [Bot] and 3 guests
