obd0 to obd1 conversion
Postby hondacodes » Sat Sep 22, 2012 11:30 am
Hey guys I'm trying to convert to obd1 from obd0 in my 89 Rex. I have the a6 block and z6 head. The distributor was put on where only 1 of the bolts is on so I plan on get in a new one. My question is what parts do I need to get. Reason I'm doing this is because I plan to supercharge very soon and have new injectors and want to tune obd1
1994 ford explorer (brother totalled)
91 crx si (brother totalled)
88 prelude si sold b20a5 not fun lol
04 Subaru impreza Wrx sold
Mako 89 crx si my dd :)
my build thread
viewtopic.php?f=2&t=60419&p=646098#p646098
hondacodes
Re: obd0 to obd1 conversion
Postby Tian90crx » Sat Sep 22, 2012 11:50 am
here you go..
http://www.rywire.com/catalog/obd0-to-o ... s-p-9.html
check all that apply at the bottom
Aftermarket Quality Turbo, Suspension, interior parts FOR SALE http://crxcommunity.com/viewtopic.php?f=8&t=156674
Tian90crx
Postby hondacodes » Sat Sep 22, 2012 1:02 pm
Do I still need to buy obd1 dizzy? And will I have to buy a new ecu? Would it be better or possible to go obd2?
my build thread
hondacodes
Postby Tian90crx » Sat Sep 22, 2012 1:32 pm
don't go obd2..
yes you need obd1 ecu and dizzy.. hence the "obd1 conversion"
Tian90crx
Postby hondacodes » Sat Sep 22, 2012 1:52 pm
should i buy the z6 dizzy from rywire as well as the chipped p28 ecu they offer?
http://www.rywire.com/catalog/distribut ... -p-29.html
http://www.rywire.com/catalog/chipped-obd1-ecu-p-3.html
my build thread
hondacodes
Postby Tian90crx » Sat Sep 22, 2012 2:07 pm
only if you want to :wink:
Tian90crx
Postby daveb91 » Sat Sep 22, 2012 2:11 pm
Tian90crx wrote:don't go obd2..
But you can also use a obd2 distributor.
daveb91
Postby hondacodes » Sat Sep 22, 2012 2:17 pm
what do you mean only if i want to lol?
my build thread
hondacodes
Postby hondacodes » Sat Sep 22, 2012 2:20 pm
are the 3 items i will need?
just to clarify before i order
my build thread
hondacodes
Postby hondacodes » Sat Sep 22, 2012 5:02 pm
will i also need to buy the 4 wire 02 sensor?
my build thread
hondacodes
Postby hondacodes » Sat Sep 22, 2012 6:21 pm
1 x OBD0 to OBD1 ECU Conversion Harness
-Distributor Adapter: OBD0 to OBD1
-VTEC Subharness: Add VTEC & 4-wire O2 plugs!
- Engine Type: D16z6
1 x Chipped OBD1 ECU
1 x Distributor [TD-42] d16z6/d15b VTEC 1992-1995
just ordered these along with a walbro 255lph fuel pump now just needa install these and my jrsc and have it tuned! should be complete in the next week or two.
my build thread
hondacodes
Postby Tian90crx » Sat Sep 22, 2012 6:32 pm
Yep, only first two links don't work..
yep also sub-harness makes everything simple, i've used rywire's complete obd0-obd1 swap.. had 0 down time with wiring on a 2000 b16a2 into a crx si..
Yes you will need a 4 wire o2.. get it for a 92-95 civic si or just reg civic..
Do you have a build thread? I would like to see the jrsc.. :-)b
Tian90crx
Postby hondacodes » Sat Sep 22, 2012 8:21 pm
my build thread
hondacodes
Postby daveb91 » Sun Sep 23, 2012 11:45 am
How about contacting rywire.
daveb91
Postby hondacodes » Sun Sep 23, 2012 1:56 pm
They keep saying theyre closed must be because the weekend. Im pretty sure it is the correct one
my build thread
hondacodes
Postby daveb91 » Sun Sep 23, 2012 3:07 pm
Always tomorrow can't order or ship today.
daveb91
Postby EF RaceRR » Mon Sep 24, 2012 12:44 pm
When I converted to OBD1, I had to first convert it to MPFI (I have a DX and did this part myself). Then I bought the Rywire ecu adapter harness. Totally worth it. It was more time-effective than doing it myself.
R Spirit
EF RaceRR
Postby Treezy » Mon Sep 24, 2012 3:34 pm
Since I'm doing the same swap with my B16a1, and boosting, I have a question.. I was told by one of the guys at rywire that I would need an injector adapter harness as well if I planned to run larger injectors than roughly stock. OP is doing DSM 450cc and I'm looking at 750cc. Do I need an adapter, and does the OP? I've asked a few friends who've done similar swaps and gotten different answers..
Founder, Evasive Illusions MSC
*Owner of the Only AWD 5G Prelude*
1991 EDM EE8 Turbo B16A1 "Black Betty"
Treezy
Postby daveb91 » Mon Sep 24, 2012 4:16 pm
Well thread jacking but what style injectors are they?
daveb91
Postby hondacodes » Mon Sep 24, 2012 5:09 pm
i was also told i need an injector adapter, the rep at rywire said i need to find out which vehicle my injectors came from, the we dsm 450cc from an 98 turbo ecplipse.
my build thread
hondacodes
Postby daveb91 » Mon Sep 24, 2012 5:45 pm
hondacodes wrote:i was also told i need an injector adapter, the rep at rywire said i need to find out which vehicle my injectors came from, the we dsm 450cc from an 98 turbo ecplipse.
Blue or black top inj, blue tops which is what I have on the JRSC setup didn't need anything just plug and play.
daveb91
Postby Tian90crx » Mon Sep 24, 2012 8:39 pm
If its low impedance (blue) its plug and play like Dave said.
If its high impedAnce then just remove resistor box
Sent from i.d.s
Tian90crx
Postby hondacodes » Tue Sep 25, 2012 7:08 am
I have black top so I should remove my resistor box? Where is it located?
my build thread
hondacodes
Postby Treezy » Tue Sep 25, 2012 1:40 pm
Interesting... So I thread-jacked by asking a relevant question which had a direct bearing on the OP's thread and build (which just so happens to correlate to my own build), but may have been overlooked since it wasn't mentioned anywhere in this thread or in his build thread.. Oh wait.., he has a black top injectors.. I wonder if he needs to do anything for those :|
Good luck on your swap and build HC, I'll be starting mine sometime soon too.
Treezy
Postby Tian90crx » Tue Sep 25, 2012 3:17 pm
google, checking resistance with an ohm meter...
then you will know 100%
Tian90crx
Return to Modification Garage
Users browsing this forum: Baidu [Spider], crocrx, MSNbot Media and 5 guests
