bobski said:
Back of the headlight down low. There's a little funnel kind of opening that you stick a phillips head screwdriver into. Under the opening, there is a toothed adjuster - the screwdriver meshes with the teeth like a set of gears so the adjuster moves when you turn the screwdriver.
Bobski, it works like a charm! I did a 9006 to 9005 conversion in there and it is an excellent upgrade. only side effect is that the 9005 bulbs doesn't last as long 300 hrs vs. 1000 hrs... But it is pretty cheap to replace. Super easy upgrade, highly recommended and it retains the "stock" look but give more like.
I guess it folks want the "whiter" light, can try the Silverstar 9005...
Now, I need to aim them properly, looking for a flat wall and level surface at night time and 25ft back!!
