Thanks for the replies.
And yes, it is an 87 carbed chassis with an 85 fuel injection swap that I'm trying to complete. It just doesn't run the way it ran before I pulled the motor... and its irritating. I swapped everything over that I could swap over, so everything
should [/i]be plug and play.
And looking at the ecu lights, the code converted or whatever from binary would be a 5, numbers 1 and 4 lit up. I also briefly had a code 3, 1 and 2 lit up. Both show up as MAP sensor codes... so I dunno. I runs very rich, and I don't know what to look for to diagnose.
After looking at the MAP sensor, which changed how the engine ran when I applied vacuum from a vacuum pump, I began to look at the fuel pressure regulator...and replaced it with one from an 88-91 Civic...with no change.
One last question... when (if) 1gen ECUs store two or more codes, how does it display them?
I thought "1" was thre O2 sensor?
I know this is for 2gens... but I'm not sure if that is a code for the 1gen...
