1 - 5 of 5 Posts
First things first, I just bought an 87 CRX si and the sunroof needs to be replaced. I would like to find one and install myself but not sure how easy that will be. (finding or installing) So I was wondering, does first and second gen CRX sunroof fit on either? Second, the brakes are soft but pads are good as well as fluid. And last is the clock keeps going back to 1:00 no matter how many times I set it.
Any suggestions?
Thanks
Jason
· Administrator
You'll need a 1st gen sunroof, a 2nd gen panel won't fit. For some leads on finding and installing a panel, you'll have more luck with a forum that has more experience with 1st gens, probably 98% of this site is 2nd gens. Check out Red Pepper Racing. You're certainly still welcome here though.
Did you bleed the brakes to make sure there are no air bubbles? Did the fluid look brown or rusty or anything unusual?
The clock resetting is most likely a loose ground somewhere.
I recently bought an 89 SI and the brakes went to the floor every time, no matter how many times that I bleed them. I took it to shop to have them looked at and found out that the master cyclinder diaphram was shot and there was leakage around the booster and it ( the master)needed replacing. after I replaced it, my brakes work perfect.
A tell tell sign of the leakage was the paint peeling on the booster around the master cyl. Not sure if this applies in your case, but figured it's worth mentioning.
1 - 5 of 5 Posts
