Um...the MAP sensor doesn't connect to the charcoal canister... it connects to the throttle body right below and to the passengers side, the vacuum port is pointed directly at the firewall. The vacuum port on the IACV directly below the MAP sensor and pointing to the drivers seat area (through the firewall) needs to be capped.
Reset the ECU for 15 seconds or so, and try that and see if it helps.
Let us know if it helps or not.
