1 - 3 of 3 Posts
Ok so I have had my rear struts replaced and I still seem to rub my tire when i hit bumps on the left rear. The right rear is fine, but also when my car is on a flat surface you can see it dip on that side, it is lower. Could it be the shocks that need to be replaced or any other ideas??? Thanks
87 crx si probably does not have struts. my 85 crx si has springs ie. coils over the shock. Mine were sagging..left side almost 2 inches and the right about an inch. I bought coil springs off of advance auto ( internet order)... trw lifetime warranty cargo coils and the ride height is at spec on both sides and handling, alignment, and ride are much improved! Could be your solution too.
1 - 3 of 3 Posts
