The car would idle and that was about it, anytime i stepped on the gas it would rev fine for a little and eventualy die out after that. I belive it was running way to rich. The only code thrown was code 11. I tried to wire in the IMA sensor (EDM spec PM7 ecu).
There was no more codes being thrown but same as it was doing before. I went through and made sure the basics were there like spark, fuel, and air. All checked out even though the car was running a little rich.
Since I butchered the crap out of my dx main harness i firgured it would be easier to get a new one and just replace it and start over from sctach. The only harness I could get a hold of came from a 89 crx si. Not only did I get the main harness I also got the rear harness, the engine harness, the cluster harness, and a few other harness. I installed the the main si harness this weekend and the only connector that did not match up is the one that ties the main harness to the rear harness (besides the engine harness which i will take care of this weekend). The connectors are called c402on the main harness and c501 on the rear harness.
The problem i am running into is the one for the si has 13 pins and the one for the dx as 18 pins. i could just swap the rear harness but when i was doing ohms checks on the harness to see where the pins went a couple of them i had to go further down from the connector to get continuity which tells me there is a break some where. I'd much rather leave the dx rear harness in there and repin it to meet up with what the si main harness.
Hopefully somebody as a pinout for the harness or a wire run listing for it.
thanks
