Pretty common swap. Check the Modification forum FAQ's.stnapycnaf said:
This should help you get started.
http://crxcommunity.com/viewtopic.php?t=5402
Pretty common swap. Check the Modification forum FAQ's.stnapycnaf said:I have a stock 91 HF ... and I would like to swap in an A6 ...
I couldn't really find a thread on this ...
Why can't he just bolt his existing exhaust including the exhaust manifold directly onto the si engine?godruler said:The only thing is you will not have a Cat on your car after the swap as the HF's Cat is in the manifold, not underneith the car, therefor an HF midpipe is longer than an SI's and goes straight to the Collector at the downpipe.
forgot about this... if you want to retain the stock intake, you cannot use the a6 intake manifold because the throttle body is much too big for the hf intake snorkel to fit around. You could however use the hf manifold on the a6 engine but that becomes a little retarded because it part way defeats the purpose of swapping in an a6 for more power.stnapycnaf said:I have a stock 91 HF ... and I would like to swap in an A6 ...
I couldn't really find a thread on this ... but I'd just like to leave everything else in [tranny, exhaust, intake]
I've actually done this swap, and I can verify that is true. It doesn't matter on Godruler's car because he has a B18, but it does for the A6 with the oddball sensor.Chassis-Specific Notes
There are a couple of little things you need to know/do with the DX and HF models. If you have an Si you're pretty much all set to swap.
The HF has little tiny axles and hubs/brakes. It is recommended that you swap them out for at least CRX Si hubs and brakes. The HF axles will work with other D series transmissions (DOHC ZC aside) because they have the same inner size and spline count, but if you're pulling the axles out anyway, you might as well do yourself a favour and swap the hubs.
With the HF, you also will need to do some minor rewiring to use the FICSV on OBD0 manifolds like the one on the D16A6. Matt Miner provided this information when I did an A6 swap into an HF:
Next is the fast idle control solenoid valve (FICSV), which is mounted on the back of the Si intake plenum, near the EACV. Its plug uses 2 wires: black/yellow and blue. Black/Yellow (later referred to as B/Y) is a 12V + and routes to the B/Y from the EACV plug. The blue wire goes to pin B2 on the ECU. B2 is currently connected to the green/yellow wire from the "shift up light" in the gauge cluster. The plug for this wire contains a green/orange and a yellow/red wire. It is under the driver's side of the dash, connected alongside the fusebox with a white plug. Cut the green/yellow wire from the plug on the harness and splice in the blue wire from the fast idle control solenoid valve, with the new wire going toward the ECU. Don't connect the FICSV wire to the plug under the dash, or weird stuff will happen with your shift light! The "shift up" light is now disconnected (YAAAAAA!!!) and the green/yellow wire on the plug under the dash now hangs bare. FICSV wiring is now complete.
