There are many main reasons for the early failure of vehicle batteries, such as:
1. The first is deep discharge: that is, when the vehicle has been stopped, but the lighting or other electronic devices on the vehicle are still in working condition, so that the battery is always in a state of discharge. Keeping the battery in a state of discharge for a long time will prolong the service life of the battery. reduce.
2. Electrolyte volatilization caused by overcharging or overheating of the engine: Since the electrolyte is prepared from special sulfuric acid and distilled water in a certain proportion, when the vehicle engine is overheated, the volatilization of the distilled water will definitely be accelerated, so that the sulfuric acid in the electrolyte and the distilled water will evaporate. The proportion of distilled water is inconsistent, resulting in shortened battery life.
3. The generator belt is too loose and leads to insufficient charging: everyone must know that the generator of the car is to supply power to the electronic equipment on the vehicle and to charge the battery during the use of the vehicle (except in the idling state), and to charge the battery. If the belt on the generator If it is too loose, it will cause the generator to charge the battery insufficiently, thus affecting the normal use of the battery.
4. The battery has not been maintained for a long time: When the vehicle has not been used for a long time (6 months or more), then the generator cannot be relied on to charge the battery. We need to maintain and charge the battery separately. Long-term parking may lead to the loss of battery power, and if the battery is not maintained, the service life of the battery will definitely be greatly reduced.
