ADVICE PLEASEEE
179 Views 7 Replies 3 Participants Last post by  RamaCrx
Hi
I need a fuel pump for my Honda crx sir 1990 (jap import) b16a
Wondering what you guys recommend and where I can buy
Thanks
1 - 8 of 8 Posts
Walbro 190 (or smaller) from APE
Thanks for the reply
I can get a walbro 255, it says that they would be fine on other forums?
Would that make a difference being a 255
Also mechanic said something about an ignition switch but not sure what that would mean
Thanks for any advice
255 is a bit much, would need to change the FPR to bypass enough fuel.
Thanks for the info
struggling to find UK supplier for 190lph
Any idea about the ignition switch
I use a 255 with aftermarket FPR. Ignition switch is available at most parts retailers. It's not hard to replace on the CRX. 1989 HONDA CRX 1.6L L4 Ignition Starter Switch | RockAuto
Thanks for the advice I guess I need to find Sir jdm ignition switch
My guess is that the switch is the same. The cylinder is seperate on the CRX.
1 - 8 of 8 Posts
