As you might remember, I found a pretty cool Momo wheel at the local junkyard a while back. I was there today and decided to pull the hub off the car (del sol). I was told an EG hub will fit the CRX, but the stalks on the column might be a little too close. Well, the hub was 5 bucks, but the bolt holes in it were a little messed up, so I retapped them. When I pulled the wheel, it was attached to the hub with wood screws, which screwed up the threads. When I went to mount the wheel, I realized the holes were in the wrong spot by a few millimeters, and the raised center wouldn't quite fit inside the steering wheel center. So I guess I'll be getting a new hub. Anybody know what kind of wheel has a similar (but different) 6-bolt pattern?
