1 - 3 of 3 Posts
I finally got around to installing an alarm on my 88 CRX ive got everything hooked up and wired correctly, however the installation manual says that when running the entry points directly to the dome light, I need to wire up to the dome light negative connection. My pin switches have the positive wire of course but they ground themselves by simply making contact with the chassis. Should I run the wire from the alarm harness directly to the negative connection on the dome light and solder, or???? Any help would be much appreciated, Thanks.
1 - 3 of 3 Posts
