A mini me is a nickname for the Z6 or Y8 head swap.Tiersin said:
A mini me is a nickname for the Z6 or Y8 head swap.Tiersin said:Oh, one more thing, what exactly is a "Mini Me"? I've herd it everywhere, but i dont know what it is.
last i knew the combustion in the chamber came as a result of a spark. the timing of this spark has nothing to do with CR but can be advanced or retarded as needed...Stavros said:Either one will be a "mini-me" swap. the problem with mounting either one of those heads is higher compression ratio (which means early explosions in your combustion chamber, BAD for your car!!! think... piston going up in cylinder, but combustion happens to early... piston still has to go up... what will break first, piston? conn rod? head gasket?)
Yikes let me clear this bit of misinformation up if I may.Tiersin said:No, hes right on this, the AF mixture can ignite itself under lots of heat and pressure. This is how Diesel engines work...which is good for them, but not good for Rex's
ollie caught it but let me further clarify the point - higher compression than the stock 9.1 doesn't automatically mean early explosion. Early explosion (detonation) happens because the CR is too high for the octane gas being run. Lower octane gas has a faster burn rate therefore is more susceptible to detonation. Compressing the AF mixture creates heat. Heat can set off lower octane gas sooner than it can higher octane gas. Very high CR as in 13+ to one would definately mean early explosion if run on street octane. That's where the misinterpretation came in. For the requirements of a 10:1 or so CR mini-me, premium octane pump gas would be sufficient.these heads are both (?) SOHC Vtec heads, and will give you a bit more kick than the standard A6 head. Either one will be a "mini-me" swap. the problem with mounting either one of those heads is higher compression ratio (which means early explosions in your combustion chamber, BAD for your car!!!
Correct.if you dont swap your ECU with the head (and mess with the wiring) then you will have to rig up a Vtec control switch, which still works, but it wont be as effective, since the ECU vtec control also changes the fuel curve if im not mistaken.
