90-91 Integra for all of those parts. Get non-ABS axles.
That is correct, Seti, yours is right too, but since we didn't get B16s stock, we can't get axles unless they come with the swap and they usually don't.
90-91 Teg axles, non ABS, remember to remove your dust ring from your hub or you will kill axles fast. The Teg axles fit, and work, but they are a little bit too long, removing the ring reduces the chance of wear, good mounts do the same.
Half shaft, 90-91 teg.
Throw out bearing, 90-91 teg.
Throttle cable, any teg 90-93, get the bracket too.
Get a 90-93 teg clutch cable too. Save yourself the hassle. With some mounts, the stock clutch cable will not allow you to adjust your clutch, the factory teg one allows all the adjustment you would want.
