1 - 3 of 3 Posts
Found this on another forum, thought i would be great for the FAQ so people arent always asking how much to torque a bolt on their B-swap.
CYLINDER HEAD BOLT TORQUE SPECS (tightening) / (loosening)
8, 4, 2, 6, 10 <---intake order 3, 7, 9, 5, 1
7, 3, 1, 5, 9 <---exhaust order 4, 8, 10, 6, 2
Torque in steps: 22ft-lbs (264in-lbs), Then to 63ft-lbs (756in-lbs) (final spec) 94+ Teg
Torque in steps: 22ft-lbs (264in-lbs), Then to 61ft-lbs (732in-lbs)(final spec) 90-93 Teg / B16's
CAMSHAFT COVER SPECS
13, 9, 5, 1, 3, 7, 11 (side of cam cover closest to intake)
14, 10, 6, 2, 4, 8, 12 (side of cam cover closest to exhaust)
Shown above is one cam cover, sequence is the same for intake and exhaust cam cover.
#1-10 20ft-lbs (240in-lbs) #11-14 7.2ft-lbs (86in-lbs) (94+ B18C specs)
#1-10 16ft-lbs (192in-lbs) #11-14 8ft-lbs (96in-lbs) (B16A specs)
**not sure what the specs are for non-VTEC motors, sorry**
Seat each camshaft by pushing it towards the dizzy side of cylinder head.
VALVE COVER SPECS
7______________5______(Intake side of valve cover)
_____3____1____
_____4____2____
8______________6______(Exhaust side of valve cover)
7.2 ft-lbs (86in-lbs) (all B series)
FLYWHEEL TORQUE SPECS
_______1
_____6___8
___4_______3
_____7___5
_______2
Torque in steps: 19ft-lbs (228in-lbs), 38ft-lbs (456in-lbs), 57ft-lbs (684in-lbs), Then to 76ft-lbs (912in-lbs) (all B series)
PRESSURE PLATE TORQUE SPECS
_______1
_____6___3
_____4___5
_______2
Torque in steps: 5ft-lbs (60in-lbs), 10ft-lbs (120in-lbs), 14ft-lbs (168in-lbs), Then to 19ft-lbs (228in-lbs) (all B series)
FUEL FILTER BANJO BOLT
25ft-lbs (300in-lbs) (94+ Teg specs)
16ft-lbs (192in-lbs) (90-93 Teg / B16 / 89-91 Civic CRX specs)
FUEL FILTER SERVICE BOLT
11ft-lbs (132in-lbs) (94+ GSR specs)
9ft-lbs (108in-lbs) (90-93 Teg / B16 / 89-91 Civic CRX specs)
HEADER A-PIPE TO B PIPE (x3)
40ft-lbs (480in-lbs) (all B series)
B PIPE TO CAT (x2)
12ft-lbs (144in-lbs) (all B series)
SHIFT LINKAGE EXTENSION ROD TO TRANNY BOLT (8x1.25mm)
16ft-lbs (192in-lbs) (90+ Teg specs)
12ft-lbs (144in-lbs) (B16 specs)
SPEED SENSOR TO TRANNY BOLT
9ft-lbs (108in-lbs)
ALTERNATOR TOP BOLT
17ft-lbs (204in-lbs) (all B series)
ALTERNATOR BOTTOM BOLT
33ft-lbs (396in-lbs) (all B series)
CRANKPULLEY BOLT
130ft-lbs (1560in-lbs) (90+ Teg)
If the crankpulley bolt is new:
145ft-lbs (1740in-lbs) loosen it a little, then re-tighten to 130ft-lbs (final spec)
87ft-lbs (1044in-lbs) (B16A, first gen)
**not sure what torque is for B16A2 and B16A3's**
TIMING BELT TENSIONER
DRIVER SIDE BRACKET TO BLOCK (x3)
DRIVERS SIDE BRACKET STUD AND BOLT
54ft-lbs (648in-lbs) (all B series)
DRIVER SIDE ENGINE TO CHASSIS MOUNT BOLT
TRANNY MOUNT TO TRANNY BOLTS (x3)
TRANNY MOUNT TO CHASSIS BOLT
REAR ENGINE BRACKET TO TRANNY BOLTS (x3)
43ft-lbs (516in-lbs) (1 passenger side) 86.8ft-lbs (1041in-lbs) (2 driver side) (94+ Teg specs)
43ft-lbs (516in-lbs) (90-93 Teg / B16 specs)
REAR ENGINE BRACKET TO MOUNT BOLT
43ft-lbs (516in-lbs) (all B series)
REAR MOUNT TO REAR SUBFRAME BOLTS (x3)
TRANNY TO BLOCK BOLTS (x5)
47ft-lbs (564in-lbs) (all B series)
LONG AND SHORT STARTER BOLTS
CLUTCH COVER LOWER BOLTS (8mm)
CLUTCH COVER UPPER BOLTS (6mm)
9ft-lbs (108in-lbs) (all B series)
INTERMEDIATE SHAFT TO BLOCK BOLTS (x3)
28ft-lbs (336in-lbs) (all B series)
FRONT AND REAR STIFFENER TO TRANNY BOLT
42ft-lbs (504in-lbs) (all B series)
FRONT AND REAR STIFFENER VERTICAL BOLTS
INTAKE MANIFOLD BOLTS
EXHAUST MANIFOLD BOLTS
23ft-lbs (276in-lbs) (all B series)
BALL JOINT CASTLE NUT
LCA TO DAMPER FORK LOWER NUT
DAMPER FORK UPPER BOLT
32ft-lbs (384in-lbs)
32mm AXLE SPINDLE NUT
134ft-lbs (1608in-lbs)
OIL DRAIN PLUG
TRANNY FILL PLUG
TRANNY DRAIN PLUG
29ft-lbs (348in-lbs)) (all B series)
SPARK PLUGS
this is such an amazing list, i honestly thought i was gonna have to search all these different specs specifically, praise the community!
1 - 3 of 3 Posts
