1 - 8 of 8 Posts
honda service manual for 94 gsr b18c1 states:
main bearing cap bolts. 56 ft. lbs
apply engine oil to the bolt threads and washer.
note: after torquing bolts turn crankshaft to check for binding
the gsr motor as a bearing cap bridge and the bolts that hold that down are torqued to 49 ft lbs
im assuming that the torque spec would be the same or simmilar
hope that helps but i dont have a manual for the b16
scarponze
· Premium Member
Just back them off and retorque them.Your fine...
Discussion Starter · #8 ·
i platigaged with the green ones that measure from .001- .003 and numbers 2,4,5 were all .0015 and 1 was .002 and number 3 which is the one that i dont believe is within spec is .001. Not enough clearance? but im gonna re platigage with 56 ft/lbs and see what i get.
1 - 8 of 8 Posts
