1 - 4 of 4 Posts
is yours the buddy club V-con vtec controller thats black with just one single knob and it has different settings on it???????
i have one i was going to use in my 93 civic with a mini me but i never got it running right the head was bad the cam journals were too far gone to work with the stage 3 cam i had in it!!!
im guessing its the same one i have
red- 12v
black-ground
gray-should be the light in the box
green-vtec selnoid
yellow-i cant quite remember but i think its the wire that goes to the ecu
because the ecu has pin points of course and there is one that is vtec coming in from the vtec selnoid and one going out to the selnoid and i am prety sure that the yellow one comes out of the ecu going to the vtec selnoid so when you adjust your v-con to the rpm you want vtec to kick in you can adjust it with that box and that controls every thing.
dose this make any since if not ill say it in better form.
1 - 4 of 4 Posts
