1 - 4 of 4 Posts
you will need the b18 harness, b series swap mounts, correct ecu. Either a prefabbed linkage or modify an integra ls linkage, needs to be shortend a little bit. is it obd-1? if so youll need the jumper harness as well.
also what trans do you have? cable or hyrdo?
You don't need a harness. Infact I would convert the engine over to OBD0 by getting an OBD0 Dizzy for an LS. With a chipped OBD0 PR4.
You have an Si, it's a plug and play setup with an LS.
You will need:
Mounts
Axles
Shiftlinkage
Throttle/clutch cable from a 90-93 Teg
That's all I can think off if you have a complete engine package off the top of my head.
1 - 4 of 4 Posts
