You forgot:
money- The ITR B18 is pretty much the most expensive B motor. Besides that, great choice.
Great choice in my book. Getting the c5 or the c1? Hydro conversion of hasport seems the best and since there are few cable ys1 trannies around now, I think its a worthwhile choice. Make sure you get lsd or add on quaife otherwise you will be sitting still spinning your wheels.red89si said:Ive decided that the best swap for me right now is going to be a 96 B18C swap, So Ive started a list of things Ill need and the parts buildup is beginning... Since I already have my car converted to OBD1, thats one less thing to worry about.
motor mounts- should I go hasport, or are there other hydro to cable B series mount kits that work better or the same for less money from other manufacturers? passwordjdm has recently quit selling hasport and switched to a brand named innovative mounts...Ive heard a little about their crossmembers, but nothing on their mount kits, anybody know anything?
CV axles- Will the standard 90-93 Integra axles work, or will I have to get custom axles such as hasport, gator racing, raxles, etc.?
shift linkage-this may very well be a stupid series of questions, but Id rather be safe than sorry. First, is all B series shift linkage created equal, Second, is it best to get your shift linkage from the same company that makes your mounts?
wiring and ECU-What all changes need to be made on all the gritty details of wiring?(injector clips, alternator connection, starter connection, all the fun stuff of that nature?) As mentioned, the car is OBD1, what else needs to convert? On rywires' website, they mention that a reprogrammed P28 runs this motor quite well..
clutch-Does anyone out there have a recommendation on a brand of clutch for this swap?
radiator- Is a replacement crossmember a must have? And would it be best to run a 92-95 Civic radiator?
Thats all I can think of at the moment, and Im sure Ive left a few things out, So to all who have knowledge of this swap, feel free to add your knowledge to this thread, it will be most helpful.
How many LS/VTEC and CRVTEC's have you seen blow up? honestly...?d16z6rex said:eh, i know why i would do it. ive seen too many lsvtec/crvtecs break and blow up. personally, id do/am doing a GSR swap, most of the power, fraction of the cost. and I got my GSR motor up over type r power for pretty cheap
Im using Hasport EFB2 Mount kit, Hasport shift linkage, Rywire Harness, chipped p28, Z10 Traction Bars, and a Fluidyne full size radiator. Im using an ACT HDSS clutch and ACT Prolite flywheel.
[email protected]
Again bro, its subjective...d16z6rex said:Ive seen 2 personally. Both LSVs. One of them had continual oiling problems, whcih may have been a build issue, then, after a head gasket replacement, ended having clearance issues and interference killed that motor.
The other one was built fine, but was never able to be tuned 100 percent. No matter what was done, it would ping ridiculously. He richened it up to the point of black exhaust and it stopped ping but ran like crap. It just seemed like so much work and money for somehitng not very reliable.
On the othe rhand, building my GSR motor was cake, and didnt cost me very much to go from 155whp to 194whp, and its every day reliable.
I mean, people cna do whatvere they want, but if it were my car, Id start with a GSR or an ITR motor if I wanted all motor power.
A K swap is definitely an option, if its in the budget. Definitely not an economical swap. I dunno, this is just the way I feel.
as a side note, if i had to pick between my turbo d and my GSR, id pick my turbo d any day of the week.
[email protected]
Youve assumed correctly sir, what I forgot to put was that Im looking into the 96 spec ~B18C-R~ (or whatever the jdm engine code for it is).ComposiMo said:Oh, and by the way, to the dude who made this post....
You never specified Type-R, or regular GSR, but since everyone else is assuming you mean Type-R, i'm going to ASSume that as well... lol.
For $4500 or whatever the typer swaps are going for these days, that puts the total swap cost at nearly $6500 if you do everything "right"... it -could- still cost more, and this is all still assuming that you are doing the work yourself.
This is just a random though, but ya know, if you do it yourself (fab work and all).... you might be able to get a K in your rex for close to that same amount?ASSuming of course that you buy the parts all right... hehe.
And by "K", i'm referring to a K20A2, not the Type-R K, but still a great K nonetheless...
Composimo: you definitely have my attention on the GSR/LS crank&rod swap :wink: , care to elaborate a little more on what all is involved in getting the LS rods and crank to fit accordingly? If a GSR block is 1795ccs and the LS block is 18XXccs is there some kind of height issue between the two?ComposiMo said:red: as i said up there in my reply to Matt, the LS bottom end gives you something way better than slapping an R badge on anything will give you..... displacement. It isn't much, but it DOES make the difference... thats why a simply LS/VTEC swap WILL (when assembled properly) make more power than a Type-R... also, don't get caught in looking at only the HP numbers... check out the torque curves when you are comparing motors... that means more. So while your type-R might put 200hp to the crank, my lowly lsvtec is putting 200 to the wheels.... with a considerable amount more torque as well. Yea, it IS better from that standpoint. No, it won't give you the "brownie points" i guess from parking-lot-nut-swingers since it isn't an R, but who cares? Its your car, don't you want it to be faster?![]()
