I just traded one of my project cars for a 98 spec GSR motor. I plan to swap this into my 1990 Si. I have searched the internet for days on a write up for doing this. It doesn't seem to be too popular. I am assuming because of the cost of a GSR/ITR motor. The motor part will be easy as I have done plenty of swaps. I am not too sure on the wiring portion and running OBD1 on a OBD2 engine.
Here is what I have so far. I am currently running a D15b2/D16z6 mini me. The harness is already wired for GSR plugs thanks to the previous owner.
Parts list:
B18C1 Engine Complete + Tranny + Harness uncut.
98 GSR ECU ( Assuming the motor is a 98 also. Have not looked at head stamp yet)
GSR Dizzy OBD2 from the looks
Integra axles. Came with motor.
Innovative EF to B series motor mounts
Innovative hydro tranny conversion kit + shift linkage
DX throttle cable. I think this will work
Still need an intake
Chip kit and P28 ECU.
Since it would be stupid to convert from OBD1 to OBD2 I am hoping that my OBD1 D16Z6 Dizzy will work in the GSR head. I have read that it does as the ears/leafs line up. Also, I don't know if 98 Integra axles will fit 90 Si hubs. Other than wiring those dumb secondary butterfly valves for the intake manifold am I missing anything? I should be able to tune out the knock sensor and secondary o2 sensor.
I also wanted to get this bar'd but a friend of mine said that even if I converted to OBD2 I still would not be able to. Lame!
Any write ups, guides, or information from anyone that has does this swap would be greatly appreciated.
Thanks! :bounce:
Parts list:
Thanks! :bounce:
