Ever had one of those Saturdays when you start on a seemingly simple task that ends up taking all day?
I am still trying to diagnose code 1 (oxygen content) and wanted to start at the very beginning with the fuel pressure check (page 11-96). The car runs and drives great. Rented a test kit from Autozone and tested this morning. Initially the gauge showed some pressure but after I bled off the pressure, it remained mostly at zero, not only after priming the system several times but also while idling.
I then rented another test kit from Oreilly with the same results. Initially, the pressure went up to 40 with the key in the on position but after that nothing. Car still started fine but the gauge read just above zero. "Impossible" I thought. It needs fuel pressure to run. Must be the gauge. But two separate gauges?
Then, while idling, I decided to clamp the return line with the following result:
PSI gradually increased to 33 PSI and stayed there with vacuum line connected and return line unclamped. Disconnecting return line caused pressure to rise slightly. Pinching return line caused pressure to increase to near 36 psi.
Second gauge:
Pinching return line caused PSI to climb from 0 to 36 psi before settling to 34-35. Disconnecting vacuum line had no effect on fuel pressure.
According to the manual, the operating range is between 35-41 psi.
After shutting the engine off, pressure dropped by 4 psi in ten minutes. No leaks at the rail. No evidence of leaky injectors.
I'm thinking of replacing the regulator but they're kind of spendy. I just don't understand why I got a zero reading at idle?!?! It had to have pressure.
Second gauge:
