Like I said before.
Chair, blanket, porch light, shotgun.
I 2nd that motion. Its cheaper too. (as long as you have the gun...)SETI20 said:Like I said before.
x10.com has some simple and relatively cheap security systems and wireless camera rigs (be aware that the latter run in the 2.4 GHz junk band, so if you have a 2.4 GHz phone, you may get beating in the picture). The security systems are easy to set up--basic kit comes with some door/window sensors a motion sensor, and a wireless key fob and control module to turn the system on and off. Makes a loud noise and flashes light. The web site sucks tho.mithuth said:auto on/motion sensor camera mounted inside the garage 9along hte back wall) facing the door so you can catch thier faces if they come back.
that last option sounds good... but sucks because i have 3 other people in my house that regularly go in the garage.bil said:x10.com has some simple and relatively cheap security systems and wireless camera rigs (be aware that the latter run in the 2.4 GHz junk band, so if you have a 2.4 GHz phone, you may get beating in the picture). The security systems are easy to set up--basic kit comes with some door/window sensors a motion sensor, and a wireless key fob and control module to turn the system on and off. Makes a loud noise and flashes light. The web site sucks tho.mithuth said:auto on/motion sensor camera mounted inside the garage 9along hte back wall) facing the door so you can catch thier faces if they come back.
If you want something cheaper, I found a really simple motion sensor alarm at lowest--four buttons, you encode a key, and use that to arm and disarm.
