Ok, I was trying to fix my climate control. Nothing works but the front window defogger. I replaced the unit with a unit I know was working. The same problems. I started messing around with the wiring running to the heater/ac unit and blam-O. I blew the battery main fuse (60amp) under the hood. It was so hot it melted the bottom of the fuse case to the fuse itself. So, what could be the problem. I'm going to try and find some fuses around town. What could have caused it to blow? Everything on the climate control worked but the little green lights above the buttons you push for feet/middle/top. I checked all the other fuses. Are there relays anywhere? Any suggestions would be great! Oh, this is on an 89 CRX DX. Oh, the rear defroster doesn't work either. The little light doesn't even come on.
BP
BP
