1 - 11 of 11 Posts
I got some issues with the brakes on my 91 crx si...I replaced the mastercylinder the lines in the rear shoes drums wheel cylinders in the rear!The reason I replaced was a spongy pedal now theres a stiff pedal until i start the car then I have nothing!Before it was allways spongy I dont understandThere is no air in the lines I bleed the crap out of the lines front and back!Any suggestions?I should also add that Engaging the brakes Messes with the idle of the car! :twisted:
I would try replacing the hoses first. No reason replacing the booster if it doesnt need it.
Discussion Starter · #7 ·
Brothers park area by guss's!That was gonna be my next guess was the booster!Would the booster make it have a good pedal until u start it tho?Thats the thing that blows my mind.I thought if the booster was shot then the pedal was shot Regardless!Well I guess thats next then!
Have you ever noticed when you get into your car, and first press the brakes, before starting, you can maybe move the pedal 2 inches? After you start the car, you can push them ... oh, 6inches? Thats your booster providing vacuum assist to enact the brakes.
to be honest, thats one part I have never FULLY removed, lol. I know there are 4 12mm bolts that you need to hire a midget to get to around the steering column. As for how it detaches from the pedal, I've yet to take the time to figure that one out.
Administrator
Those aren't even the hard bolts on the pedal assembly. The brake booster is held to the brake pedal by a bolt with a cotter pin through it.
1 - 11 of 11 Posts
