1 - 6 of 6 Posts
hey im in need of a few tips of how to remove the entire brake line system from my 91 hf. im removing them because some im gonna hide them others because im going to get the car painted interior and out so im going to get them out the way. I cant unscrew them from there threads. ( passanger side engine bay) also were the master cylinder is also where they attack to the actual brakes i no its a 10 mm but all it does is slip and strip. Also any1 with tips are welcomed.
You need what is called a "line wrench"..
A special wrench with six points..
If the fittings are already stripped,
Sometimes you can bust them loose
with a good set of vice grips..
I see this is old but I seriously hope that you do not plan to take your brake lines off just to have the floor painted . .. to do know that you are going to have to bleed all of the brakes and probable snap off a few wheel cylinder and caliper bleeders in the process. . . . if is isn't broke. . . .
1 - 6 of 6 Posts
