This all started about four months ago when I started noticing a squeak from my brakes. I thought that it was most likely time for some new pads. Well, being tight on money, I went out and bought front pads only. I don't buy cheap pads so they were the Hawks HPS pads. I found a weekend where I had time to do them and started on the project. Started on the right side and got done with them in no time. The problems start on the left side, got it all apart, changed the pads, and started to push the piston back in, wouldn't move. So I went to the local shop and asked them if they had the brake caliper tool, which they did and let me borrow, and finished the job that way. About a week later, all you could smell was burning brakes. Looked at the rotor, and you could see it was starting to turn blue from the heat. Went back to the shop and bought a new caliper, at cost, and swapped it out. The next week, the smell was back. It seems the right caliper didn't want to be away from its failing buddy and failed itself. Went back to the shop and order another caliper. The lady ordering the part at the store doesn't really know either how to read or how to listen because it took four times for her to realize that an SI is different from a normal CRX, so I kept getting the wrong caliper for the car. (Note to all, the squeaking hasn't stopped yet. Must be the rears.)
Fast forward to yesterday. I get some more cash in my pockets so I go out and buy the pads for the rear. I know you need a tool for the rear, which seems to be very hard to find because I've been looking and still haven't found it. My school has it but won't let me use it because I'm not in the brake class, no help there. So, another trip to the shop where we are now on a first name basis; He has the tool but wont loan it to me, so he does the next best thing. Lets me do the work at the shop on the lift. (using a lift is so much easier) I'm now calling this man a lifesaver. Started pulling the wheels off and I notice that the calipers look to be in the same condition as the fronts were in but think nothing of it. Pull the calipers off and see that the brakes do need to be changed, good thing I'm doing them. I go to start pushing in the piston and low and behold, they won't move. Try WD-40 and a lot of force, still nothing. So, I had him order me up some new calipers for the rear and here I wait. The brakes just haven't been giving me a brake lately. I go back Friday to install them and hope the car gods will be happy for at least the winter because my funds are running low.
I'm seeing a lot of Silver linings being said so here is mine,
Silver lining. I know the brakes are going to work now and should for a long time to come.
