90-91 I believe. Just the front knuckles, the rears are a trailing arm setup. Check fastbrakes.com for a bunch of different brake kits. You might look in to Wilwood brakes, we use them on the Baja Car (see my avatar) and they've held up to all the crap we've done to them (lots of stuff, they work completely submerged in water, long story on that one), not sure if they have a civic application though.
I've read on here about using NSX brakes on a CRX, you might look in to doing that conversion and using NSX aftermarket brakes, they'd certainly be showy enough for you.
