Cam Gear
1130 Views 4 Replies 4 Participants Last post by  Dren
I have a cylinder head sitting here that ia m rebuilding and I want to know how to get the cam gear off to install an aftermarket one. The manual I have assumes the cylinder head in still on the motor. Any suggestions?
1 - 5 of 5 Posts
Hold the cam on one of the lobes with a large adjustable crescent wrench (seriously), and then blow the bolt off with either an impact gun, or hold it down on top of a workbench while a buddy breaks the bolt loose. If it makes you feel better, you can put a lightweight cloth over the cam, and then grip it with the wrench, but only ONE layer... don't wrap it thick.
Then, if it won't just slide off the cam, use a rubber mallet to tap around the edges of the gear, to knock it off the cam... make sure you catch/keep/retain/find after loosing the key that keeps the gear from rotating on the shaft 8)
If it's a D16 head and it's got the stock cam gear, the key is cast into it.
1 - 5 of 5 Posts
