1 - 3 of 3 Posts
motorolla 2.5 bar I think is the norm if you don't do 3bar and should be plenty as the stock one can go to -I think- 12 psi, though your ecu can't understand that unless it's chipped.
Yeah everything is built and running well at 9.5-10 psi. (ZDYNE) The map sensor was something I kinda overlooked and on the dyno it became obvious that I should of had one. Now I am trying to cut as many cost corners as possible and found the 2 bar a bit cheaper. I'll check out the 2.5 now...
1 - 3 of 3 Posts
