Welcome to the community
There are a few things to check.always start with the cheapest alternative first.
If your problem is idle, check:
1. Idle Air Control Valve, test it with 12vdc, and make sure it's clean.
2. Inspect distributor cap and rotor for signs of tear and wear specially that white= grayish caked over the DC contact pins.clean the rotor/button as wel. If you see its all beat up replace them both with new parts.
3. Check timing as well, SI marks on the cam gear is read at a different position than a Dx/ base model. SI top dead center mark is at or around pointing to 7:00 clock position.
4. Chances are the Fast Idle Throttle Valve(FITV) might need adjustment.
5. Don't forget to inspect and clean ground terminals at battery and chassis and transmission.
There are plenty of posts related to all those points I mention, and chances are you will see a few vids on YT as well.
Gl
Gl
