1 - 8 of 8 Posts
Well im new here i used to always be on h-t and someone told me to come here so heres my problem..after i drive my car and turn the key off somtimes it wants to just stay running but the radio turns off just the gauges and the motor stay on ...do i need a new ignition?
check to se if your cooling fan runs all of the time. . . . if someone wired it direct... when you shut the car off the spinning fan can actually make power and bleed back through the system and keep the car running for a little bit. . . . .i have ran into this alot on early 80's gm cars. . . it was kinda funny you would get out of your car after you turned it off and it would stay running for about a minute after you walked away from it. . .
check that first..
Chris
True, the first gens here in the US (and some second gens elsewhere) are carbed. I was looking at his avatar and thinking his wasn't though. Also the gauges... the tach might work but the temp and fuel etc shouldn't.
drnknmnky13 said:
Aren't the early CRX's carbed? Or are they all FI?
It says nowhere about hime having an early crx. . . .if its the one in his avatar then its a 2nd gen. . .. and judging from his prev posts. . .it just got a b18 swap. . . .
I would check out that ignition switch a little better. . ..
and see whats going on there..
1 - 8 of 8 Posts
