black_krix_si said:
double check the wires going to the starter. there is a little wire that has a spade type connector. I had an 88 DX and it would always come loose then the car wouldnt start.
i put a new clutch in my rex sunday... as this was probably the 40+ time i have done one with no problems, i was tiard and not paying attention and got the little starter wire (stated above my black_krix_si) smashed between the engine and tranny. my car didnt start. i found the problem quickly atleast.
i also elected to just cut the wire instead of undoing everything and soldier on a new wires/connector... just to get to take it all back apart tonight becuase aparently boost and 8lb flywheels dont work to well together aparently...
i would recomend double checking
both starter wires. if there hooked up make sure they have power when there suposted to.
ground wires... especially the ground on the thermostat if you took it off...
wires cought inbetween engine/trans check good they like to hide from you
ignitions switch could be bad if your using the new one... its a posibility
scarponze
