i have a pm6 ECU but i also have a blue connector with two pins hanging theredownest said:If you have OBD0, pull back the carpet on the passenger floor and you can see the ECU LEDs. If you have OBD1, jump the connector under the glovebox area, it's blue with 2 pins, and your CEL will flash the code.
Why is that? Most OBD-0 ECUs don't make use of the long blink. The HF does have an EGR system... What's the problem?d16z6rex said:thats odd, it shouldnt be blinking 12x.
