Trying my luck here, cause im at a dead end.
1991 crx si
Ive done the climate control control swap to the Accord unit. Everything is wired correctly, and all functions work.
However:
The ground wire coming out of fan speed selector switch heats up too hot to hold with fingers. I have not soldered the connection yet due to this problem.
All grounds are testing good, have either been cleaned, replaced, and or upgraded.
I have 2 accord units, both do the same
New: fan speed selector switch, blower resistor.
I bypassed wiring harness by taking the ground straight to negative on battery, no change, still gets too hot.
Could there be too much voltage coming in to the unit?
1991 crx si
However:
