Ok, lets see, where should i start. Ah, it all started with the tach fluctuating higher RPM's. You guys said replace the distributor, which I did and it fixed the problem. Unfortunately, on Monday that distributor seized. I put the old one back in, and then replaced its coil with the one from the seized dist. Now the tach won't go below a grand even when the car is shut off. And the car is throwing a code 17. After looking at the book I found out that its a vehicle speed sensor. Other than that I can't find anything in the book about it. I was talking to a mechanic friend of mine who gave me a printout of test procedures that's two pages long. Hoping you guys know what the answer to my problem are.
