1 - 3 of 3 Posts
I'm going to attempt to put the rear trailing arms and disk brakes from the si onto the dx on saturday. I'm also going to be putting on the front calipers and the master cylinder.
Couple questions:
Do I need to bring over the Si proportioning valve also? (methinks yes)
Is there a difference in the e-brake cables from the Dx and the Si?
Any other advice?
I've done plenty of brake work before so I'm not terribly stressed about this. it just seems time consuming. I'll also be trying to put in the Mugen trailing arm bushings onc ei have the Si arms out.
Can this be done with a regular arbor press? or do I need a hydraulic press?
Haha I think this chick is annoyed I'm posting while getting my haircut. Yes on the p valve. Yes the cables are different. The mugen bushing requires you to push out the sleeve as well right? If so any press will press that out, I'm just used to es and retaining the sleeve. I think that was qll your questions. Good luck with the ebrake cables, they are a pain!
Hahaha, alright. Thanks, I'm sure it'll be fine.
Goodluck with your haircut!
1 - 3 of 3 Posts
