Jack it up in the center and put the jack on the outside frame rails near the front doors
Ok maybe my hydraulic jack (sears) is lame ... If I put it under the center jack point I can't get the crx up high enough to put the stands under the side jack points with the pins though the jack stands .. have to put the extension all the way down which makes me nervous. So I end up jacking under the front LCA. Maybe I need to get new jack stands that have a lower minimum height.whitey2g said:Jack it up in the center and put the jack on the outside frame rails near the front doors
Just a thought in case you missed this, my jack and all the others I've seen have a threaded pole. If yours does, you can jack it up as far as it will go, put a jack stand under it, then spin out the threads making the jack longer, jack it up some more, and reset the jack stand. I do this one corner at a time so the tilt doesn't get bad. Remember tho that the higher the car is, the more unstable it is on the jack stands. I always supplement the jack stands with some else (in my case, logs).'9445 said:Ok maybe my hydraulic jack (sears) is lame ... If I put it under the center jack point I can't get the crx up high enough to put the stands under the side jack points with the pins though the jack stands .. have to put the extension all the way down which makes me nervous. So I end up jacking under the front LCA. Maybe I need to get new jack stands that have a lower minimum height.whitey2g said:Jack it up in the center and put the jack on the outside frame rails near the front doors
I've done that too with my janky jack. Works well at least a couple times.rex2nr said:if you can't lift the front enough, place a couple pieces of 2X4 on your jack. It will give you a couple inches of room.
im having a real hard time imagining what youre talking about a "threaded pole".bil said:Just a thought in case you missed this, my jack and all the others I've seen have a threaded pole. If yours does, you can jack it up as far as it will go, put a jack stand under it, then spin out the threads making the jack longer, jack it up some more, and reset the jack stand.
Nope, not stock if you mean the one with the car. I've got a small oil cylinder jack, the central rod that does the lifting is in two pieces. The core is threaded, so you can unscrew it upwards. So you place the jack on the floor, unscrew the core section until it meets the car, then close the port and lift the car.rex2nr said:He's probably referring to a stock jack.
Yeap, that's the kind. I've only used it under the cross members or the jack points. When I get a shop, I'll go looking for a shop jack. ('toxiclows said:I think he is talking about having a bottle jack. . . . verses the regular shop type jack. .
the bottle jack will work. . . but you really should shop around for a nice full size service jack. . . .
i one pump is nice too where when there is no load on it 1 pump will bring it right up to the frame and then you can star pumping it. . . if you have to use the bottle type jack make sure you use it somewehre solid like the front crossmember. . . . if you jack under a unibody rail or the floor or the rocker lip. . . . the small head on it will most likely go up through your floor with the weight all concentrated on that small little circle. .
