I drove my car out of the shop and home yesterday. It's alive after:
new front bumper
new bumper turn signal lenses
new 3/4 glass on the passenger side
new window on the driver side
new door weather stripping on the driver side
new door spring thingie that goes from the door to the hinge to keep it from flying out too far
new passenger fender
a ton of wheel well fasteners (get them off the acura's they have metal screws instead of the crappy plasitc screws)
12 buckets of black soapy water and a bottle of tilex to clean the interior
new corner lenses
new valve cover gasket
new radiator and hoses
new plugs and wires
new distributor
new CV axles
new passenger side headlamp tilt adjustment screw
new fuel pump
new tires
The only thing the shop did was replace the fuel pump and adjust the timing belt to start the car. Fired right up with full compression and passed emissions on the second try (after they ran a half tank of gas through it).
The car had been sitting for several years and was partially parted out. I'll be working on getting the rest of the interior bits together and changing the timing belt and water pump ASAP.
Thanks everyone for your help and advice for a Honda newbie! I've asked a ton of questions and more will be coming.
new front bumper
new corner lenses
new plugs and wires
new distributor
new CV axles
new fuel pump
new tires
