Your best bet with the ignition will probably be to replace the whole unit. This would mean you'd have a different key than the doors, so hopefully you can get the door lock cylinders from the same car. Another advantage to this is that a potential theif can't just copy down your VIN and get his shady hookup at the dealer to cut a key for your car.
The LS engine is a B18. 1990-93 Integras came with a B18A1, 94-01 tegs had a B18B1. In Honda engine codes, The first letter represents the engine "family" in this case B-series. The two-digit number represents the displacement, in this case 1.8 liters. Anything after that indicates a "sub-model" of that engine code. You can learn more in the modification forum, where Downest has his engine swap guide.
More bang for the buck on header vs. turbo? A header is a simple bolt-on affair in the range of $300 with the benefit of around 5-10 hp. A turbo is big power and will require much much more. For starters, you'll have to tap your oil pan to run oil to the turbo, go with larger fuel injectors and possibly a larger fuel pump to get sufficient fuel flow, engine management to control the huge new amount of air getting to the engine, etc. You can piece together a cheap turbo setup for around $1k, but to do it "right" is more in the range of 4 thousand and up. My advice is to stick with a header for now until you better understand what you'll need for turbo.
The cruise control just looks ugly in there! I've never been a fan of it either. Cruise is an excuse to not be paying attention, imo. I'd rather be completely in charge of my car for every second it's on the road.
