Just Wondering somthing... imma gonna go turbo on my crx and JW wat kinda injectors would i use for my ZC, its a OB0.. wat can i do??? how can i tune the car???
Oh i have a 1991 crx si... and yeah how are you supose to chip your ECU with turbo edit... how do you do that and how much does it cost?? wat year dsm injector do i need to use???ZeniceguyCRX said:you can use dsm 450cc stock injecors and chip your ecu with turboedit
if your crx is a 90-91 si your computer is easy to chip if not you neeed one.
check out
www.homemadeturbo.com
Its a much better system, i find cars run alot better and smoother after a conversion.downest said:Personally I would convert to OBD1. Not only are there benefits for tuning, but you are also set up for any future swap.
well all imma looking for is about 7 psi onli... just wanna run turbo safely... oh yeah one more thing... well e-management work for ZC???ZeniceguyCRX said:chiping for turbo edit is easy and teh software is free. If your only gonna run a stock engine at 10psi your fine with turbo edit. Just have it tuned off the base map and your good to go
