1 - 5 of 5 Posts
Random info taken from threads on Honda-Tech, OneCamOnly, and NapaOnline.com. I've double and tripple checked everything to the best of my ability.
D15B2 - 106 teeth, 24mm wide
D16A6 - 107 teeth, 24mm wide
D16Z6 - 104 teeth, 24mm wide
D15Z1 - 103 teeth, 24mm wide
jlicrx said:
84-87 JDM CRX/Civic Si "Browntop" (1gen - serial # beginning with 1 - vacuum advance ignition) DOHC ZC - 129 teeth, 24mm wide
88-89 JDM Integra "blacktop" (2gen - serial # beginning with 5 - electronic ignition advance) DOHC ZC - 129 teeth - 24mm wide
86-89 USDM Integra D16A1 - 129 teeth, 24mm wide
88-91 JDM CRX/Civic Si DOHC ZC (3gen - OBD0) - 124 teeth, 24mm wide. Can use 88 Prelude Si (2.0) Belt.
92-95 JDM Civic DOHC ZC (4gen - OBD1) - 124 teeth, 24mm wide
B16A - 124 teeth, 26mm wide
B18A - 125 teeth, 26mm wide
B16B/B18C - 126 teeth, 26mm wide
D15B2 (88?-91 CRX DX) Belt Specs Taken from Napa Online):
# of Teeth: 106
Pitch: 9.5mm
Pitch Length: 1010mm
Width: 24mm
Profile: Modified Curvilinear (III)
Tensioner: .427" x 2.228" x 1.716"
B18A (91-93 Integra LS) Belt Specs (Taken from Napa Online):
# of Teeth: 125
Pitch: 9.5mm
Pitch Length: 1191mm
Width: 26mm
Tensioner: .4381" x 2.165" x 1.448"
H22 (98 Prelude) Belt Specs (Taken from Napa Online):
# of Teeth: 155
Pitch: 8mm
Pitch Length: 1240mm
Width: 24mm
Tensioner Bearing: .4331" x 2.4409" x 1.4173"
chillez said:
dohc zc- same as old prelude belt so you could find specs for that one.
I saw some information on RedPepperRacing saying they are and aren't the same, depending on what year DOHC ZC you have. But I'll look into it when I have time.
84-87 JDM CRX/Civic Si "browntop" (1gen - serial # beginning with 1 - vacuum advance ignition) DOHC ZC - 129 teeth - 24mm wide
86-89 USDM Integra D16A1 - 129 teeth - 24mm wide
88-91 JDM CRX/Civic Si DOHC ZC (3gen - OBD0) - 124 teeth - 24mm wide
92-95 JDM Civic DOHC ZC (4gen - OBD1) - 124 teeth - 24mm wide
1 - 5 of 5 Posts
