I've recently been reading up on porting, I'm going to port the other Y8 head I have and build another high-compression D16. Jared has also started working on porting the three A1 heads we have for the teg, but he's mostly cleaning up rough casting and smoothing the port-to-valve seat transitions. I read this article on Endyn's site, and I sent them an email a few days ago, but I haven't received a response yet, here is the email:
Any insights? I want to get started on this soon, I've located all the parts I need. Now that I have a non-broken ignition system, this thing should put out some good power.
The bottom-end work referenced is from this article.Hello:
I've been looking at your engine building tech articles for a while, and I'm planning to use your suggestions on my high-compression D16 build. What kind of aluminium epoxy do you recommend for use in the engine, that won't break down? Is JB Weld or something similar ok to use? Also, what do you use to open the main bearing holes up? It seems like they might shatter or crack easily, I've never machined them before. I'm also porting the head, it's a D16Y8 head for this engine, and my friend is working on a couple of D16A1 heads for our turbo 89 Integra rally/ice race car. For each application, how should we treat the dividers in the ports for each of these applications? In your article, you left it slightly rounded for "NA with occasional nitrous" use. The Y8 head will be on a mini-me running roughly 12.5:1 compression, with a stage 2 for now, soon to be stage 3 Crower NA cam, used for daily driving, frequent autocross, and occasional HPDE. It will never see nitrous or forced induction. The A1 is being built with PM6 (D16A6) pistons to lower compression slightly and boosted probably no more than 10 psi on either a T25 or a Mazda/Garrett IHI turbo. The integra head for now is going to remain stock other than the porting and cleaning up the chambers as per your articles. It's interesting to note that the casting in the ports of the A1 head is terrible, rough transitions and ugly casting marks extend pretty far back from the valve seats. One last thing, could you explain the practice of squaring the edges of the main girdle? I understand what to do, I'm just not sure I completely understand the benefits of doing it.
cheers
tom downes
