1 - 1 of 1 Posts
just did the compression calculator from zealautowerks and this is what the results were http://www.zealautowerks.com/
Block-B16A
81-Bore (mm)
77.40-Stroke (mm)
203.25-Deck Height (mm)
Head-B16A
42.70-Combustion Chamber Volume (cc)
Piston-PCT (JDM B16B)
8.63-Dome (cc)
30.73-Comp Height (mm)
Connecting Rod-B16A
134.00-Rod Length (mm)
Headgasket Thickness-OEM 3-layer
0.02600000-Thickness (in)
0.00-Bore diff (mm) *
Maxium Operating RPM-8000
Elevation-fl which is 100ft
Results
Static Comp Ratio-11.91: 1
Effective Comp Ratio-11.89: 1
Displacement-1595.55cc
Rod / Stroke Ratio-1.73
Piston-to-Deck Height-(-0.007)
Mean Piston Speed-1713fps
Max Piston Acceleration-114842fps2
1 - 1 of 1 Posts
