1 - 20 of 21 Posts
DOHC ZC OEM & Aftermarket Parts List
  • -OBD-1 Distributor Cap and seal: 1994-2001 Integra LS & RS B18 non vtec models.
    OBD-1 Distributor Cap part #
    OEM Acura - 30102-P54-006 -- listed price through Majestic Acura is $21
    -Distributor Cap gasket
    OEM # 30132-PM5-A02
    -Rotor Button
    88-91 Civic/CRX // 88-89 Integra
    Brand-----Part#
    OEM - 30103-PM5-A05
    WELLS - JP923
    VALUCRAFT - 33-8220
    -Spark plug wires
    88-89 Acura Integra
    Spark Plug Wires
    Brand-----Part#
    OEM -
    MSD - 32339
    MAGNECOR - 45125
    NGK - NGK-HE48
    NOLOGY - 011014011
    **If not going for High performance wires USE OEM all others are inferior except for performance wires.**
    -Spark plugs
    Dont waste your money on platinums or iridiums
    NGK is standard from Honda. If your Boosting the motor choose your type carefully as a standard plug is not for you, you will need a colder plug.
    88-91 Civic/CRX si 1.6L // 88-89 Integra
    Brand-----Part#
    NGK V-POWER - BCPR6E-11
    Spark plug tube seals
    86-89 Integra
    OEM # 12342-PT2-000
    -Distributor O- ring and CPS O-ring
    88-89 Integra
    OEM # 30110-PA1-732
    -Oil Filter
    The S2000 OEM Filters will work also and are made by a reputable company in Japan that makes high performance oil filters, but you will pay more for them.
    MY Suggestion...Get OEM Its only a couple bucks so why buy others when you can have a OEM filter for mostly the same price.
    Oil Filter
    Brand-----Part#
    OEM -
    STP - S2808
    FRAM - PH6811
    K&N - HP-1004
    MOBIL - M1-104
    -Cylinder Head Gasket
    1988 & 89 Integra
    Brand-----Part#
    OEM - 12251-PM7-003
    FELPRO - 9451PT-1
    HKS GROMMET - 2302-RH001 (0.6mm Thick/76mm Bore/10 CR)
    HKS BEAD - 2301-RH010 (0.7mm Thick/76mm Bore/9.9 CR)
    -Head StudsARP
    Part # ARP 141-4204 Dodge Neon SRT-4
    Head Studs
    Brand-----Part#
    ARP - ATP6.760-1lb ?? * needs verifying for 100%
    -Intake Manifold Gasket
    1988 & '89 Integra
    Brand-----Part#
    OEM - 17105-PG6-S00
    FELPRO - MS93362
    -IACV (Intake Air controll valve)
    88-91 Civic/CRX
    oem # 36455-PT3-A01
    -Exhaust Manifold Gasket
    1988 & '89 Integra
    Brand-----Part#
    OEM - 18110-PG6-003
    FELPRO - MS93363
    -Rear Main Seal
    1988 & 89 Integra
    Rear Main Seal
    Brand-----Part#
    OEM - 91214-PH1-013
    -Front crank seal
    1988-89 Integra
    Front Crank Seal
    brand-----Part#
    OEM - 91212-PEO-662
    -Cam seals
    1988-89 Integra
    Cam Seals
    brand-----Part#
    OEM - 91203-PG6-013
    -Oil Pan
    88-89 Integra
    -Oil Pan Gasket
    Brand-----Part#
    OEM - 11251-P01-004
    FELPRO - OS30542R
    ROL - OS5725
    -Header
    88 - 91 CRX/Civic Headers will fit. The ports are off just a tad but the bolt pattern is money. Nothing a little grinding can't fix.
    -Timing Belt
    1988 Prelude 2.0 Si.
    Timing Belt
    Brand-----Part#
    OEM - 14400-pk2-004 NOTE:I have heard people get part #14400-pk2-003
    they should be the same
    -Timing belt tensioner
    OEM part # 14510-PM7-004
    -Engine and tranmission Mounts
    1988 - 1991 CRX/Civic (All trim levels)
    Engine and transmission Mounts
    Brand-----Part#
    OEM - 50810-SH3-040 (Rear, Firewall Mount)
    OEM - 50805-SH3-040 (Transmission Mount)
    OEM - 50821-SH3-040 (Side Mount, By Timing Belt)
    OEM - 50840-SH3-000 (Front Mount)
    -CPS (Cylinder Position Sensor)
    1988 & 89 Integra 1.6l
    Brand-----Part#
    OEM - 37841-PG7-006
    -Transmission
    Any 88-91 L3 transmissions will work.
    **See below for more info**
    -Throttle Body
    88 - 91 Civic/CRX Si 1.6L
    -Throttle Body Gasket88-91 Civic/CRX Si 1.6L only
    Brand-----Part#
    OEM - 16176-PM6-S00 or 16176-PM6-000
    -Radiator Hoses
    *Upper: 88-89 Integra
    *Lower: 88-91 Civic/CRX
    Radiator Hoses
    Brand-----Part#
    OEM Lower Hose - 19502-PM3-000
    OEM Upper Hose -
    -Valve cover Gasket
    86-89 Integra
    Valve Cover Gasket
    Brand-----Part#
    OEM - 12341-PM7-000
    -Spark plug tube seals
    86-89 Integra
    -Valve cover stud Grommets
    90-93 Integra 1.8L
    **OEM part # 90442-PR3-000
    -Valve Cover Studs (outer and 1 in Center)
    1990-93 Integra B18, 97-2000 CR-V B20
    Valve cover Studs
    Brand-----Part#
    OEM - 90012-PM7-000 (this is the outer ones)
    OEM - (I need the inner stud part #)
    -Thermostat
    88-91 CRX/Civic
    Thermostat
    Brand-----Part#
    Stant OEM TEMP - 45878
    Prestone OEM TEMP - 392180
    -Alternator
    88-91 CRX/Civic
    Get a NAPA if you must use other than OEM, but try to stay OEM here if you can. Advance and Autozone and most other parts stores Have VERY LOW quality replacements...**Why do you think they have to offer a lifetime warranty??..( a little something to make you think)
    Brand-----Part#
    OEM - 31100-PM8-A03RM or 31100-PM8-A03RMD
    -Water Pump
    88-91 CRX/Civic
    Water Pump
    Brand-----Part#
    OEM - 19200-P01-003 or 19200-P01-004
    -Water Pump Gasket
    *If your gasket is leaking You might as well get a new pump and it will come with the gasket*
    -Oil Pump
    88-91 Civic/CRX
    OEM # 15100-P06-A01
    -Fuel Injectors
    88 - 91 CRX/Civic Si / 86-89 Integra
    Fuel Injector
    Brand-----Part#
    OEM - 06164-PK2-010
    BOTTOM END components
    -connecting rods
    But any D-series 1.6L rods will work for upgrading.
    -Pistons
    88-89 Integra OEM
    There are many companies that offer ZC specific Pistons now, so Aftermarket is there.
    -Main & Rod bearings and thrust washer bearings
    -Piston Rings
    88-91 Civic/CRX // 86-89 Integra
    http://www.thezcr.com/html/partnums.php
    I have read that serial numbers on the ZC engine can tell you about where it came from. ZCs with a serial number starting with 2 is from Civic/CR-X and with a 5 is 2nd-gen Integra.
    Also, if you look between the 2nd and 3rd cylinder (above the dipstick), above the header, you will see the 2 digit date stamp of manufacture.
downest said:
Good stuff Cory! I added it to the list in the FAQ. When am I going to see a DOHC ZC'd CRX out here?
Hey thanks Tom,very good! :D
I found the list on a Honda Motor Importer site.
Through what i know and what i have researched it looks accurate but can anyone else back me up and just confirm the accuracy of the list, so i am not posting inaccurate info.
Hopefully i can get my ass in gear pretty soon and find the time to put that tranny and header i got from you to good use and get my 2 cam Zc in the Crx.
nice info. Very good Listings. I will be referencing this as i am looking to do a DOHC ZC swap. I read that the 3rd gen ZC how do you tell a 1st,2nd 3rd gen ZC from another, i know there are Valve Cover paint color codes, what if some one painted them though is their a distinct numbering sequence on the motor or something?
first gens came in brown and bleck tops i believe, but had four valve cover bolts located on top of the cover... the second gen was obd0, had ditributor and external cam sensor, valve cover bolts on the sides of the cover.. and last was odb1 zc, from what i can tell its the same as the obd0 but internal cam sensor in the distributor... has a plug like the b series.. u can make a second gen obd1 though... but the first gens only fit in 3g civics and 1 g crxs like my white one... has driversside motor mount in front of the motor!
Discussion Starter · #13 ·
ZC info in the Mod garage FAQ's.
viewtopic.php?t=5796
Shanet90 said:
the motor in my 1g is basically the usdm version of the first gen zc its out of a 87 integra... ancient import :D
The US Integra motor, d16a1, is similar to a 1st gen ZC. It has a lower hp rating.
But with the 2nd and 3rd gen DOHC Zc's, there is no US equivalent.
Does it matter that there are to types of ZC engines (CRX and Integra)? Is the parts list the same for both?
1 - 20 of 21 Posts
