1 - 2 of 2 Posts
Newly resuurected and drove it to work today. Threw code 7 Throttle angle sensor and 16 for the Injector.
The car idles anywhere between 1000 and up to 1750 rpms sometimes.
Runs fine otherwise, getting used to the mechanical throttle cable (got spoiled by the little lady's hydraulic clutch Miatas).
Are these throttle sensors cleanable or should I replace them? If it's easier to replace, can someone set me up with a part number so I can get it at NAPA?
They don't have it listed in their system, but I figure it was used on other vehicles.
As to an injector code getting thrown, wouldn't this normally stop the car dead as it only has 2?
All help is appreciated,
What have you done to the car that it's newly running? Check to make sure the TPS is plugged in all the way, mine somehow made its way off the plug last week, but hasn't moved since (around when I got the Y49 radio). Not sure about the injector code though... If you do need to replace the TPS, you will have to drill out the rivets that hold it with an easy-out, or slot them and unscrew them (they are in threaded holes).
1 - 2 of 2 Posts
