Please take into consideration, before the roast, that the JDM versions don't have cables that attach to the climate control unit. We have the auto aircon controller that's all electronic that hooks to a motor that controls the air blend door.
And yes, I searched. I found this particular thread to be somewhat helpful.
The thermostat is new, and so is the water pump (saw people asking those questions on other threads).
The climate control unit, when the defrost button is pressed, the motor moves the door to the defrost vents. When the floor/defrost option is selected, the fan moves the door to open the floor vents. When I push the warm button I hear and get nothing.
The knob that selects the temperature doesn't affect the temperature if it's moved to cool or warm.
I took the climate control out today to inspect that all plugs were plugged in, and they were, so it can't be the climate control unit itself.
Going into the engine bay, I located the heater valve. With the cable attached, I was unable to open or close the valve. If I detached the cable, I can freely move the valve open or closed. With the cable detached and the valve all the way open (pushed towards the firewall), I still get no heat even though the hose going to the firewall feels warm to the touch.
So I pulled out the glovebox and removed the evaporator. When I did that, I found two connectors that were disconnected - a 5P and a 3P.
The 5P connector is actually a 6P with only 5 pins terminated. I could only make out 4 out of the 5 colors, but it appears to be a YEL, BLK/YEL, BLU/ORG, BLU/RED, ???
The 3P connector is BLK, PNK, BLK/YEL
I have no idea where these go to, but if you go to the thread I linked at the beginning of this thread, you'll see that the same 3P connector is visible on their JDM harness:
I don't want to tear out my dash to figure out what these connect to. Does anybody have any experience with the JDM climate control heat not working? I haven't been able to find a single BLK-PNK-BLK/YEL 3P connector on any wiring diagrams!
