My temperature gauge started to flutter upwards. Overheating? Well, I was traveling on the highway in near freezing weather with the heater on. But then I also had these other issues:
1) A/C Compressor failed to come on. I turned it on because that cuts on the extra fan.
2) Radio speakers cutting in and out.
3) Check Engine codes 1, 17, and 20!
After turning on and off the radio, the headlights and basically jiggling everything, all returned to normal. A/C compressor came on, radio worked normally, etc. I replaced the grounds and battery terminals about a year ago.
I have had problems with my main relay in the past. Could the loose contact be causing this while driving or am I looking at a short someplace?
