yea i need to know if a d15b7 will just bolt in to my 1991 CRX Si?and will the wiring have to be done after or before the i bolt it in?
You would need a conversion kit for rywire.com. Or you can get your ecu chip and use everything else from your D16 except the engine, which would be D15b7/ Yes, you would use your tranny/clutch/flywheel.blackcrx18 said:oh i see.what do i need to jump it over to obd1?can i still use the transmission that is on my d16a6 engine?
oh i can run it obd 0 and it will run fine?what do u mean by "if your worried about fuel maps and timing chip your obd0 eculudesrv said:You can run it obd1 or you can stay obd0. If your worried about fuel maps and timing chip your obd0 ecu. A d15b7 doesn't justify the 150$ kits or the hours of soldering if you don't buy it.
yea those kits are like $150 arent they.which ecu are u talking about.no i havent swapped an engine before this is my first time and my friend know how to bolt it in and hes gonna help me,my bro was supposed to help me but he doesnt have enough time or so he saysludesrv said:You would need a conversion kit for rywire.com. Or you can get your ecu chip and use everything else from your D16 except the engine, which would be D15b7/ Yes, you would use your tranny/clutch/flywheel.blackcrx18 said:oh i see.what do i need to jump it over to obd1?can i still use the transmission that is on my d16a6 engine?
Have you ever swapped an engine?
It won't run right on the wrong ECU. It may be somewhat expensive, to convert, you might want to consider rebuilding your A6.baker423 said:Simple short answer:
Stay OBD0 & use your stock d16a6 transmission.
Well, it will run, just not as well as it's supposed to.downest said:It won't run right on the wrong ECU. It may be somewhat expensive, to convert, you might want to consider rebuilding your A6.baker423 said:Simple short answer:
could not said it better myself. . .ollie said:WAIT WAIT WAIT a minute...
A D15b7 block is the same d block as a A6..Why in the world would he need to go obd1?...
Comeon guys stop confusing the issue here.
Can you swap in a b7 motor into your crx?...answer yes,but you need to keep a few things in mind.
To save $$$ keep your setup obd0.What I mean by that is this-
You will only use the B7's block and head.You need to reuse your old (A6)dizzy,Intake,TB,and exhaust manifold.
The B7 will run fine on a PM6...
Why are we going off on converting this guy to OBD1?
Although he CAN do it that way I doubt that is what this guy is thinking.
I've been saying stay obd0. But convince the other 2 that you don't need to be the OBD of the engine. You can make an engine run perfect without having the 'proper code ecu'. And if he WAS really worried about it, he could always chip his PM6 ecu to run the P06 map for alot less then going obd1.toxiclows said:could not said it better myself. . .ollie said:WAIT WAIT WAIT a minute...
Go this route for the simplest solution and least headaches.. . . There are improvments you can make in the future. . . but for a quick and easy swap this is the preferred method
:doh:ollie said:WAIT WAIT WAIT a minute...
Y8 swap would include spending a good bit of money buying the engine, the wiring kit and the ecu/dizzy and what not. Not worth it if your looking for the cheap route out.hcrx333 said:Why dont you go for a y8 swap if your thinking of converting or putting any sohc engine besides the a6 that you already have in there? Or just do a mini me on the a6.... anything else will not show performance gained from money spent. My thoughts anyway..... :?
B7 is rated at 102. I'm guessing the torque is down some too.ludesrv said:The d15b7 makes 108hp, just like the factory A6 did. It might not be a 'gain' but it ain't a lose.
Umm well that "hole" is a bad thing.It means that a rod has busted loose and punched an undesirable opening in your block plus the rod is most likely wedged itself in a way as to lock up your motor from turning over.blackcrx18 said:yea thats weird that hole is causing my car not to work.what does minime an engine mean?and whats dizzy mean?
